Solenoid Removed, Seeking Fuel Filter Recommendation
- Ted
4 years 8 months ago
It looks like my fuel solenoid went kablooi (that's American for 'broken') on my '81 A3. I now have the 3/8 fuel line routed directly to the carbs, but, there's no room for a standard fuel filter available locally. I haven't seen any on-line that I think will work. Does anyone half a recommendation? I can route the line under the carbs similar to the original configuration which will give me room, but obviously don't want to hinder flow.
Re: Solenoid Removed, Seeking Fuel Filter Recommendation
4 years 8 months ago - 4 years 8 months agoIt looks like my fuel solenoid went kablooi (that's American for 'broken') on my '81 A3. I now have the 3/8 fuel line routed directly to the carbs, but, there's no room for a standard fuel filter available locally. I haven't seen any on-line that I think will work. Does anyone half a recommendation? I can route the line under the carbs similar to the original configuration which will give me room, but obviously don't want to hinder flow.
Close- Kablooey-destroyed or ruined. (Real Word)
Last edit: 4 years 8 months ago by Kawboy.
After rebuilding I configured two sets of cabs like this, for a 1300 owner
WIX # 33027 used these for years. Don't let it's size fool you.
Last edit: 4 years 8 months ago by scotch.
The following user(s) said Thank You: dcarver220b, zed_thirteen, Ted
That's a clean install Scotch...
- Ted
I forgot to ask in the original post if anyone knows or has experience with how long the petcock can remain open before carbs can flood or leak into a cylinder? Obviously, overnight can do it, but how about a 1/2 hour gas stop? Yesterday, I stopped and showed the bike to a man for 10 minutes and turned the petcock off paranoid that I would find a flooded carb when I went to start it.
- rdurost
The fuel filter for a '77 Datsun/Nissan 620 pickup (2.0 liter) may be helpful. It's a cylindrical body with the outlet perpendicular to the body. The inlet is on the long axis. The filter element is high-capacity paper, and some manufacturers' parts use a clear plastic filter body, as I prefer.
