englishcw
Offline
Senior Member
Thank you received: 25
I imagine that for the cam timing to have changed, the cam chain would have to be so far from being at the correct ‘tension’ that you would have had audible warning that something was amiss in that department. Was the engine sounding rattly?
It has been awhile , but from Memory , [ 1988ish ] here is what happened to My Bike . Pulled into Service Station for Petrol [ Gas ]. Pulled out into Traffic , busy Road , no quick acceleration . Pulled off the Main Road , 30 MH limit , opened throttle , riding riding without haste . Felt hesitant , sensed , rather than felt , misfire . Assumed bad Petrol , never used that particular Service Station before , but it was always busy. Arrived Home. Removed Petrol from Tank into a large plastci container , and sure enough , I could see a glob about 6inches diameter , just like a Jelly Fish . Emptied Float Bowls , re-fitted , re-filled Tank , tested the Bike , same problem . Removed Carbs , found them spotless , and re-cleaned them to be doubly sure . Went through all the Electrics , no change . Over about Three Weeks , after Work I double checked everything , and started to doubt myself . I then , first time ever , and I have been riding since 1964 , I took my bike to a Local Shop . Went to collect , all done , they said , we balanced the carbs , all appears O.K . On the ride Home , it did feel better , but I could feel a misfire . As I had checked everything , all that was left , I was thinking , was the Valve Timing . Remember , We now have the Wonderful Internet . That is when I found the Timing Chain had jumped one Tooth , on the Exhaust Camshaft . Replaced chain [ funny story there ] , and all was good .
